Salta al contenuto principale
Gateway MA6 Laptop RAM Replacement
Cosa ti serve
  1. Gateway MA6 Laptop RAM Replacement, Battery: passo 1, immagine 1 di 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop RAM Replacement: passo 2, immagine 1 di 3 Gateway MA6 Laptop RAM Replacement: passo 2, immagine 2 di 3 Gateway MA6 Laptop RAM Replacement: passo 2, immagine 3 di 3
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop RAM Replacement, RAM: passo 3, immagine 1 di 2 Gateway MA6 Laptop RAM Replacement, RAM: passo 3, immagine 2 di 2
    • Remove the seven 6 mm Phillips #0 screws from the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
  4. Gateway MA6 Laptop RAM Replacement: passo 4, immagine 1 di 2 Gateway MA6 Laptop RAM Replacement: passo 4, immagine 2 di 2
    • Pull upwards on the top of the back cover to remove it.
  5. Gateway MA6 Laptop RAM Replacement: passo 5, immagine 1 di 3 Gateway MA6 Laptop RAM Replacement: passo 5, immagine 2 di 3 Gateway MA6 Laptop RAM Replacement: passo 5, immagine 3 di 3
    • Pull outwards on the silver metal pins to release the upper RAM module.
    • The module will automatically lift up 30° after it has been released.
  6. Gateway MA6 Laptop RAM Replacement: passo 6, immagine 1 di 2 Gateway MA6 Laptop RAM Replacement: passo 6, immagine 2 di 2
    • Firmly grasp the outer portion of the RAM module, and pull it outward to remove it from the port.
    • Repeat the same process for the lower RAM module.
Conclusione
Cal Poly, Team 6-2, Forte Spring 2014 Membro di Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,162
