Introduzione
Your laptop hard drive stores all of your files, as well as your computer's operating system. A corrupt hard drive will need to be replaced for your computer to power on and run. It is common to upgrade to a larger hard drive with more storage space.
Cosa ti serve
Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover.
Altre 3 persone hanno completato questa guida.
Un commento
It only took 2 minutes once I found te right screwdriver. Great aid!
