Salta al contenuto principale
Gateway MA6 Laptop Hard Drive Replacement
Cosa ti serve
  1. Gateway MA6 Laptop Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop Hard Drive Replacement: passo 2, immagine 1 di 3 Gateway MA6 Laptop Hard Drive Replacement: passo 2, immagine 2 di 3 Gateway MA6 Laptop Hard Drive Replacement: passo 2, immagine 3 di 3
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 2 Gateway MA6 Laptop Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 2
    • Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover.
  4. Gateway MA6 Laptop Hard Drive Replacement: passo 4, immagine 1 di 2 Gateway MA6 Laptop Hard Drive Replacement: passo 4, immagine 2 di 2
    • Press thumb down firmly on the hard drive and pull outwards to the side.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 6-2, Forte Spring 2014 Membro di Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Membri
20 Guide realizzate
Un commento
It only took 2 minutes once I found te right screwdriver. Great aid!
Reed Roloff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,850
