Introduzione
Your laptop hard drive stores all of your files, as well as your computer's operating system. A corrupt hard drive will need to be replaced for your computer to power on and run. It is common to upgrade to a larger hard drive with more storage space.
Parti
Nessuna parte richiesta.
  1. To prevent injury, make sure the laptop is unplugged before removing the battery.
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon. Firmly pull the battery outwards and away from the laptop. Firmly pull the battery outwards and away from the laptop.
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover. Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover.
    • Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover.
  5. Press thumb down firmly on the hard drive and pull outwards to the side. Press thumb down firmly on the hard drive and pull outwards to the side.
    • Press thumb down firmly on the hard drive and pull outwards to the side.
Conclusione
Altre 3 persone hanno completato questa guida.
Chris Naughton
Membro da: 07/04/2014
705 Reputazione
5 Guide realizzate
Cal Poly, Team 6-2, Forte Spring 2014 Membro di Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Membri
11 Guide realizzate
It only took 2 minutes once I found te right screwdriver. Great aid!
Reed Roloff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,329
