Salta al contenuto principale
Gateway M-2626u RAM Replacement
Cosa ti serve
  1. Gateway M-2626u RAM  Replacement, Battery: passo 1, immagine 1 di 1
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u RAM  Replacement: passo 2, immagine 1 di 3 Gateway M-2626u RAM  Replacement: passo 2, immagine 2 di 3 Gateway M-2626u RAM  Replacement: passo 2, immagine 3 di 3
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u RAM  Replacement, Back Panel: passo 3, immagine 1 di 2 Gateway M-2626u RAM  Replacement, Back Panel: passo 3, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  4. Gateway M-2626u RAM  Replacement: passo 4, immagine 1 di 2 Gateway M-2626u RAM  Replacement: passo 4, immagine 2 di 2
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  5. Gateway M-2626u RAM  Replacement, RAM: passo 5, immagine 1 di 1
    • Remember to always remove or disconnect the battery!
    • Push outwards on the metal tab to unlock the RAM stick from its position.
  6. Gateway M-2626u RAM  Replacement: passo 6, immagine 1 di 2 Gateway M-2626u RAM  Replacement: passo 6, immagine 2 di 2
    • Lift up and remove the RAM from the device.
    • Follow the same steps to remove the second RAM stick from your device.
Conclusione
Tanya Jain
Membro da: 03/19/18
317 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 138
