Salta al contenuto principale
Gateway M-2626u Hard Drive Replacement
Cosa ti serve
  1. Gateway M-2626u Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u Hard Drive Replacement: passo 2, immagine 1 di 3 Gateway M-2626u Hard Drive Replacement: passo 2, immagine 2 di 3 Gateway M-2626u Hard Drive Replacement: passo 2, immagine 3 di 3
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 2 Gateway M-2626u Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place.
  4. Gateway M-2626u Hard Drive Replacement: passo 4, immagine 1 di 1
    • Using the plastic opening tool, pry open the plastic panel covering the hard drive.
  5. Gateway M-2626u Hard Drive Replacement: passo 5, immagine 1 di 3 Gateway M-2626u Hard Drive Replacement: passo 5, immagine 2 di 3 Gateway M-2626u Hard Drive Replacement: passo 5, immagine 3 di 3
    • Using your hands, carefully pull out the hard drive from its compartment.
Conclusione
Femi
Membro da: 04/06/18
219 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 210
