Introduzione
If the CD drive is not playing your movies or musical discs, a replacement might need to be done. This guide will take you through the process of removing and replacing the CD drive.
Cosa ti serve
Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
Using the Phillips #1 screwdriver, remove the indicated 6mm screw holding the CD drive.
Quasi finito!
Conclusione
