Salta al contenuto principale
Gateway M-2626u Battery Replacement
  1. Gateway M-2626u  Battery Replacement, Battery: passo 1, immagine 1 di 1
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u  Battery Replacement: passo 2, immagine 1 di 3 Gateway M-2626u  Battery Replacement: passo 2, immagine 2 di 3 Gateway M-2626u  Battery Replacement: passo 2, immagine 3 di 3
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
Conclusione
Tanya Jain
Membro da: 03/19/18
317 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 222
