Introduzione
This is a guide for the removal and replacement of the webcam from the Gateway LT41P10u laptop.
Cosa ti serve
Carefully use a spudger to separate the monitor from top panel.
Gently remove lower hooks from the hinges. (see second image)
Using a plastic spudger or fingers gently remove webcam hardware from front screen. A gentle heat source can be used to easily remove glued down parts.
Once webcam hardware is removed from front screen, it can be removed by hand from the wiring and replaced.
Perform these steps carefully as smaller parts are more likely to break.
