Salta al contenuto principale
Gateway LT4004u Screen Replacement
Cosa ti serve
  1. Gateway LT4004u Screen Replacement, Screen: passo 1, immagine 1 di 3 Gateway LT4004u Screen Replacement, Screen: passo 1, immagine 2 di 3 Gateway LT4004u Screen Replacement, Screen: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Open the laptop so that the screen and keyboard are facing you.
    • Remove the two screw covers at the bottom right and left corners of the screen using tweezers.
  2. Gateway LT4004u Screen Replacement: passo 2, immagine 1 di 3 Gateway LT4004u Screen Replacement: passo 2, immagine 2 di 3 Gateway LT4004u Screen Replacement: passo 2, immagine 3 di 3
    • Unscrew the two 5.0mm screws underneath the screen covers on the left and right side and remove them from the laptop. For this step and the following steps, use a Phillips #0 head screwdriver.
  3. Gateway LT4004u Screen Replacement: passo 3, immagine 1 di 3 Gateway LT4004u Screen Replacement: passo 3, immagine 2 di 3 Gateway LT4004u Screen Replacement: passo 3, immagine 3 di 3
    • Once the two screws are removed, pry the screen casing away from the screen. You can use your fingernails or a tool such as tweezers to separate the screen casing from the backing.
    • Be prepared to hear cracking noises. These are expected.
    • Unhook the screen casing at the bottom of the screen from the central hinges on the left and right side connecting the screen casing to the keyboard.
    • Remove the screen casing.
  4. Gateway LT4004u Screen Replacement: passo 4, immagine 1 di 3 Gateway LT4004u Screen Replacement: passo 4, immagine 2 di 3 Gateway LT4004u Screen Replacement: passo 4, immagine 3 di 3
    • Once the screen casing is removed, unscrew the 8 screws surrounding the screen and remove them from the laptop. All 8 screws should measure 4.0mm long.
    • There is a single screw in each red indicator and two screws in each orange indicator, totaling to the eight screws.
  5. Gateway LT4004u Screen Replacement: passo 5, immagine 1 di 3 Gateway LT4004u Screen Replacement: passo 5, immagine 2 di 3 Gateway LT4004u Screen Replacement: passo 5, immagine 3 di 3
    • Unplug the webcam connection from the top of the laptop screen backing.
  6. Gateway LT4004u Screen Replacement: passo 6, immagine 1 di 3 Gateway LT4004u Screen Replacement: passo 6, immagine 2 di 3 Gateway LT4004u Screen Replacement: passo 6, immagine 3 di 3
    • Flip the screen over so that it is lying on top of the keyboard.
    • Looking at the underside of the screen, remove the yellow tape and carefully remove the wires attaching the screen to the laptop.
  7. Gateway LT4004u Screen Replacement: passo 7, immagine 1 di 1
    • Remove the screen from the rest of the laptop.
Conclusione
Clemson, Team 6-5, Benson Spring 2016 Membro di Clemson, Team 6-5, Benson Spring 2016
CLEM-BENSON-S16S6G5
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 512
