Salta al contenuto principale
Gateway LT2104u RAM Replacement Guide
Cosa ti serve
  1. Gateway LT2104u RAM Replacement Guide, RAM: passo 1, immagine 1 di 1
    • Locate the the "L" shaped cover on the back, lower right hand side the device. Using a Philips screwdriver, remove the screw holding it in.
  2. Gateway LT2104u RAM Replacement Guide: passo 2, immagine 1 di 2 Gateway LT2104u RAM Replacement Guide: passo 2, immagine 2 di 2
    • Gently lift the cover until it detaches from the device.
  3. Gateway LT2104u RAM Replacement Guide: passo 3, immagine 1 di 2 Gateway LT2104u RAM Replacement Guide: passo 3, immagine 2 di 2
    • Gently push the levers on each side of the stick of RAM away from each other until the RAM springs into a 45° angle.
  4. Gateway LT2104u RAM Replacement Guide: passo 4, immagine 1 di 1
    • Carefully remove the stick of RAM by pulling at the same 45° angle the RAM is currently at until it detaches from the device.
  5. Gateway LT2104u RAM Replacement Guide: passo 5, immagine 1 di 1
    • When inserting the new stick of ram, be sure to insert it at the same 45° angle that the old stick of ram was taken out at. Press the stick of RAM down until it clicks into place.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 464
