Salta al contenuto principale
Gateway LT2104u Battery Replacement Guide
  1. Gateway LT2104u Battery  Replacement Guide, Battery: passo 1, immagine 1 di 1
    • Locate the release mechanisms for the battery that are located near the ends of the battery
  2. Gateway LT2104u Battery  Replacement Guide: passo 2, immagine 1 di 1
    • Slide the release lock on the top right hand side of the laptop to expose the orange on the left hand side of the tab.
  3. Gateway LT2104u Battery  Replacement Guide: passo 3, immagine 1 di 1
    • Once the right battery release is unlocked, do the same for the release lock on the left side.
    • Once both are unlocked, gently push the battery out of the device. It should be completely separated from the device.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 396
