Introduzione
Once you've opened up the netbook to reach the monitor, the webcam can be easily replaced.
Cosa ti serve
Unlock the tab located in the top left corner of the netbook.
The red tab indicated that the battery has been properly unlocked.
Remove the battery.
Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Carefully disconnect two ribbon cables to complete the separation of the upper cover.
Pry the border around the monitor off of the top cover using a plastic opening tool, as shown.
Be careful not to damage the computer screen in the process
The webcam is located here, as shown.
Disconnect the webcam from the wires attaching it to the computer.
Lift the webcam away from the top cover.
