Salta al contenuto principale
Gateway KAV60 LT2016U Hard Drive Replacement
Cosa ti serve
  1. Gateway KAV60 LT2016U Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 1
    • The hard drive is located under this cover.
  3. Gateway KAV60 LT2016U Hard Drive Replacement: passo 3, immagine 1 di 2 Gateway KAV60 LT2016U Hard Drive Replacement: passo 3, immagine 2 di 2
    • Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
  4. Gateway KAV60 LT2016U Hard Drive Replacement: passo 4, immagine 1 di 2 Gateway KAV60 LT2016U Hard Drive Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to lift the cover.
  5. Gateway KAV60 LT2016U Hard Drive Replacement: passo 5, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
  6. Gateway KAV60 LT2016U Hard Drive Replacement: passo 6, immagine 1 di 3 Gateway KAV60 LT2016U Hard Drive Replacement: passo 6, immagine 2 di 3 Gateway KAV60 LT2016U Hard Drive Replacement: passo 6, immagine 3 di 3
    • Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up.
    • Lift the silver cover; this will expose the hard drive.
Conclusione
Lydia Benjock
Membro da: 10/18/13
1.216 Reputazione
10 Guide realizzate
Clemson, Team 14-3, Benson Fall 2013 Membro di Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,645
