Introduzione
If you have a Phillips #0 screwdriver, you can easily replace the 3G card.
Parti
Nessuna parte richiesta.
Unlock the tab located in the top left corner of the netbook.
  • Unlock the tab located in the top left corner of the netbook.
  • The red tab indicated that the battery has been properly unlocked.
  • Remove the battery.
  • When working with electronics, it is always wise to remove the power source before taking the device apart.
Aggiungi Commento
The 3G card is located under this cover.
  • The 3G card is located under this cover.
Aggiungi Commento
  • Use the Phillips #0 screwdriver to remove one (1) 5mm screw.
  • Use the plastic opening tools to lift up the cover.
Aggiungi Commento
  • Using the Phillips #0 screwdriver, remove one (1) 5mm screw holding the card in place.
Aggiungi Commento
  • Remove the 3G card from the computer by lifting the card up from the bottom.
Aggiungi Commento
  • Notice the two wires connected to the card.
  • Gently detach the wires from the card. The metal portions will "pop" off
Aggiungi Commento
Conclusione
Lydia Benjock
Membro da: 18/10/2013
1.189 Reputazione
11 Guide realizzate
Clemson, Team 14-3, Benson Fall 2013 Membro di Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Membri
24 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 492
