Introduzione
It is important to have a functioning Wi-Fi card because it allows you to connect to the internet when there are Wi-Fi Hotspots around.
Parti
Nessuna parte richiesta.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Aggiungi Commento
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Aggiungi Commento
  • Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here.
Aggiungi Commento
  • Pry off the keyboard by placing your plastic opening tool on the center of the top row of keys, as shown in the photograph.
  • If the plastic opening tool bends or slips, use something sturdier, such as the Phillips #0 screwdriver.
  • Remove the keyboard.
Aggiungi Commento
  • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
Aggiungi Commento
  • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
  • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Aggiungi Commento
  • The WiFi card is shown here.
  • Remove the one (1) 5mm screw holding the card to the motherboard using a Phillips #0 screwdriver.
Aggiungi Commento
  • Disconnect the wires on the Wi-Fi card.
    • This can be done easily by applying pressure to the connections until they pop off of the card.
Aggiungi Commento
Conclusione
Brian
Membro da: 11/03/2014
201 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 284
