Salta al contenuto principale
Gateway ID49C07U Screen Replacement
Cosa ti serve
  1. Gateway ID49C07U Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Screen Replacement: passo 2, immagine 1 di 2 Gateway ID49C07U Screen Replacement: passo 2, immagine 2 di 2
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Screen Replacement: passo 3, immagine 1 di 1
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Screen Replacement: passo 4, immagine 1 di 1
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Screen Replacement, Screen: passo 5, immagine 1 di 1
    • Turn the laptop over and open.
  6. Gateway ID49C07U Screen Replacement: passo 6, immagine 1 di 2 Gateway ID49C07U Screen Replacement: passo 6, immagine 2 di 2
    • Use the Small metal spudger to remove the small black screw covers in the bottom corners of the screen
  7. Gateway ID49C07U Screen Replacement: passo 7, immagine 1 di 2 Gateway ID49C07U Screen Replacement: passo 7, immagine 2 di 2
    • Use the PH1 Screwdriver to remove the screws
  8. Gateway ID49C07U Screen Replacement: passo 8, immagine 1 di 1
    • Use the small metal spudger to start separating the front plastic cover from the back plastic cover
  9. Gateway ID49C07U Screen Replacement: passo 9, immagine 1 di 3 Gateway ID49C07U Screen Replacement: passo 9, immagine 2 di 3 Gateway ID49C07U Screen Replacement: passo 9, immagine 3 di 3
    • Once there is enough room for you to fit your hand underneath the top plastic cover you can start pealing it back. It will make a lot of popping noises as it unclips when you separate it.
  10. Gateway ID49C07U Screen Replacement: passo 10, immagine 1 di 3 Gateway ID49C07U Screen Replacement: passo 10, immagine 2 di 3 Gateway ID49C07U Screen Replacement: passo 10, immagine 3 di 3
    • Once the plastic cover is off locate the 4 screws in the corners of the screen and unscrew them
  11. Gateway ID49C07U Screen Replacement: passo 11, immagine 1 di 2 Gateway ID49C07U Screen Replacement: passo 11, immagine 2 di 2
    • After the screws are out gently flip the screen over onto the keyboard
  12. Gateway ID49C07U Screen Replacement: passo 12, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use the tweezers to peal back the tape over the wire connector on the bottom of the screen
  13. Gateway ID49C07U Screen Replacement: passo 13, immagine 1 di 2 Gateway ID49C07U Screen Replacement: passo 13, immagine 2 di 2
    • Hold the tape back with one hand and pull the connector out
Conclusione
Altre 2 persone hanno completato questa guida.
Ryan Howlett
Membro da: 03/06/17
273 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 438
