Salta al contenuto principale
Gateway ID49C07U Keyboard Replacement
Cosa ti serve
  1. Gateway ID49C07U Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Keyboard Replacement: passo 2, immagine 1 di 2 Gateway ID49C07U Keyboard Replacement: passo 2, immagine 2 di 2
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Keyboard Replacement: passo 3, immagine 1 di 1
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Keyboard Replacement: passo 4, immagine 1 di 1
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Keyboard Replacement, Keyboard: passo 5, immagine 1 di 1
    • Turn the laptop over and open
  6. Gateway ID49C07U Keyboard Replacement: passo 6, immagine 1 di 3 Gateway ID49C07U Keyboard Replacement: passo 6, immagine 2 di 3 Gateway ID49C07U Keyboard Replacement: passo 6, immagine 3 di 3
    • Use the small metal spudger to push in each of the clips on the keyboard
  7. Gateway ID49C07U Keyboard Replacement: passo 7, immagine 1 di 3 Gateway ID49C07U Keyboard Replacement: passo 7, immagine 2 di 3 Gateway ID49C07U Keyboard Replacement: passo 7, immagine 3 di 3
    • Continued
  8. Gateway ID49C07U Keyboard Replacement: passo 8, immagine 1 di 2 Gateway ID49C07U Keyboard Replacement: passo 8, immagine 2 di 2
    • Use the small spudger to pick up the corner
  9. Gateway ID49C07U Keyboard Replacement: passo 9, immagine 1 di 1
    • Slide keyboard towards the screen
  10. Gateway ID49C07U Keyboard Replacement: passo 10, immagine 1 di 2 Gateway ID49C07U Keyboard Replacement: passo 10, immagine 2 di 2
    • Use the small spudger to slide the cable lock up on both sides of the connector and slide the cable out
Conclusione
Altre 2 persone hanno completato questa guida.
Ryan Howlett
Membro da: 03/06/17
273 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 648
