Salta al contenuto principale
Gateway ID49C07U DVD Drive Replacement
Cosa ti serve
  1. Gateway ID49C07U DVD Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U DVD Drive Replacement: passo 2, immagine 1 di 2 Gateway ID49C07U DVD Drive Replacement: passo 2, immagine 2 di 2
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U DVD Drive Replacement: passo 3, immagine 1 di 1
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U DVD Drive Replacement: passo 4, immagine 1 di 1
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U DVD Drive Replacement, DVD Drive: passo 5, immagine 1 di 1
    • Locate screw towards the center of the device and unscrew it
  6. Gateway ID49C07U DVD Drive Replacement: passo 6, immagine 1 di 3 Gateway ID49C07U DVD Drive Replacement: passo 6, immagine 2 di 3 Gateway ID49C07U DVD Drive Replacement: passo 6, immagine 3 di 3
    • Use a metal spudger to pry off the DVD drive.
    • Once loosened, use your hand to pull the DVD drive out.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 273
