Salta al contenuto principale
Gateway GWTC116-2BL Touchpad Replacement
Cosa ti serve
  1. Gateway GWTC116-2BL Touchpad Replacement, Back Panel: passo 1, immagine 1 di 1
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
  2. Gateway GWTC116-2BL Touchpad Replacement: passo 2, immagine 1 di 2 Gateway GWTC116-2BL Touchpad Replacement: passo 2, immagine 2 di 2
    • Use the spudger to pry the back panel away from the body of the laptop.
  3. Gateway GWTC116-2BL Touchpad Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the five 3.0 mm Phillips #00 screws.
  4. Gateway GWTC116-2BL Touchpad Replacement: passo 4, immagine 1 di 2 Gateway GWTC116-2BL Touchpad Replacement: passo 4, immagine 2 di 2
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
  5. Gateway GWTC116-2BL Touchpad Replacement: passo 5, immagine 1 di 1
    • Pull up the battery to remove from the base.
  6. Gateway GWTC116-2BL Touchpad Replacement, Touchpad: passo 6, immagine 1 di 2 Gateway GWTC116-2BL Touchpad Replacement, Touchpad: passo 6, immagine 2 di 2
    • Flick open the bracket and peel back the white cable.
  7. Gateway GWTC116-2BL Touchpad Replacement: passo 7, immagine 1 di 2 Gateway GWTC116-2BL Touchpad Replacement: passo 7, immagine 2 di 2
    • Peel the metallic tape off of the casing.
  8. Gateway GWTC116-2BL Touchpad Replacement: passo 8, immagine 1 di 1
    • Peel off the smaller piece of metallic tape that was underneath the other tape.
  9. Gateway GWTC116-2BL Touchpad Replacement: passo 9, immagine 1 di 2 Gateway GWTC116-2BL Touchpad Replacement: passo 9, immagine 2 di 2
    • Using an opening tool, dislocate the touchpad from the adhesive part of the base.
    • Repeat on the other side.
  10. Gateway GWTC116-2BL Touchpad Replacement: passo 10, immagine 1 di 1
    • Pull away the touchpad from the base of the computer.
Conclusione
Kailey Sousa
Membro da: 03/22/24
459 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 55
