Introduzione
If your touchpad on the Gateway GWTC116-2BL is not working, there may be a problem with it. There could be a possibility it has been damaged, and you need to replace it. In this guide, there is a step-by-step of how to replace a faulty touchpad. Be sure to have a new touchpad that is compatible with the Gateway GWTC116-2BL handy in order to replace the faulty one.
Cosa ti serve
Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
