Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
removal of top case
Parti
Nessuna parte specificata.
  1. Flip the laptop over. Slide the battery release tab to the right.
    • Flip the laptop over. Slide the battery release tab to the right.
  2. Lift the battery out.
    • Lift the battery out.
  3. Insert spudger between sysrq and ins keys.
    • Insert spudger between sysrq and ins keys.
    • Gently lift power button panel from the right to left.
  4. Remove the 5 screws holding the keyboard in place.
    • Remove the 5 screws holding the keyboard in place.
  5. CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge. DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
    • CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge.
    • DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  6. Remove 5 screws.
    • Remove 5 screws.
    • 4 screws holding LCD hinge covers in place and 1 screw for LCD grounding.
    • Remove hinge covers.
  7. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  8. Gently unplug LCD from system board.
    • Gently unplug LCD from system board.
  9. Remove 6 screws holding LCD to hinge.
    • Remove 6 screws holding LCD to hinge.
  10. Pull LCD away from case.
    • Pull LCD away from case.
  11. Slide release and push button to eject drive
    • Slide release and push button to eject drive
    • Pull drive out.
    • When reinserting drives be sure to insert back into original slot in order to avoid interface conflicts.
  12. Remove 13 screws from bottom of computer
    • Remove 13 screws from bottom of computer
  13. Remove screws
    • Remove screws
  14. remove 4 screws from back of case
    • remove 4 screws from back of case
  15. WARNING Failure to do this step will damage mouse pad ribbon.
    • WARNING Failure to do this step will damage mouse pad ribbon.
    • Lift plug holding mouse ribbon about 1/16 inch or until it stops
    • remove ribbon
  16. Insert spudger between upper and lower case at drive bay closest to battery.
    • Insert spudger between upper and lower case at drive bay closest to battery.
    • Carefully and slowly go arount entire case unseating all plastic clips holding upper to lower.
  17. Lift upper case free about 1/4 inch
    • Lift upper case free about 1/4 inch
    • At rear of case is one last connecting wire. Unplug and remove upper case
Conclusione
Elizabeth Mazer
Membro da: 14/10/2010
78 Reputazione
10 Guide realizzate
Cal Poly, Team 20-10, Maness Fall 2010 Membro di Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Membri
22 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,603
