Salta al contenuto principale
Gateway 600YG2 System Fan Replacement
Cosa ti serve
  1. Gateway 600YG2 System Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 System Fan Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 System Fan Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the 5 screws holding the keyboard in place.
  4. Gateway 600YG2 System Fan Replacement: passo 4, immagine 1 di 2 Gateway 600YG2 System Fan Replacement: passo 4, immagine 2 di 2
    • Potential for device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Potential for device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  5. Gateway 600YG2 System Fan Replacement, System Fan: passo 5, immagine 1 di 2 Gateway 600YG2 System Fan Replacement, System Fan: passo 5, immagine 2 di 2
    • Unscrew the four captive screws.
    • Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
Conclusione
Cal Poly, Team 20-10, Maness Fall 2010 Membro di Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,275
