Salta al contenuto principale
Gateway 600YG2 LCD Replacement
Cosa ti serve
  1. Gateway 600YG2 LCD Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over.
    • Slide the battery release tab to the right to open the battery cover.
  2. Gateway 600YG2 LCD Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover using the tab on the right side.
    • Lift and remove the battery.
  3. Gateway 600YG2 LCD Replacement, Power Button Panel: passo 3, immagine 1 di 1
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, from the right and moving to the left.
  4. Gateway 600YG2 LCD Replacement, LCD: passo 4, immagine 1 di 1
    • Remove the five screws with a Phillips #0 screwdriver.
    • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
    • Lift the hinge covers along the outer edges with the spudger until they are released.
  5. Gateway 600YG2 LCD Replacement: passo 5, immagine 1 di 1
    • Gently unplug the LCD from the system board.
  6. Gateway 600YG2 LCD Replacement: passo 6, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
  7. Gateway 600YG2 LCD Replacement: passo 7, immagine 1 di 1
    • Check if any cables are still connected before pulling out the LCD.
    • Remove the cable by gently pulling it out while holding down the LCD.
Conclusione
Cal Poly, Team 20-10, Maness Fall 2010 Membro di Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Membri
22 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,021
