Salta al contenuto principale
Gateway 3545GZ Internet Card Replacement
Cosa ti serve
  1. Gateway 3545GZ Internet Card Replacement, Internet Card: passo 1, immagine 1 di 1
    • Flip your laptop over and locate the sticker indicating where the internet card is.
    • Using a PH1 Phillips-Head screwdriver, carefully unscrew the screw holding the flap down
    • The screw length is 3mm
  2. Gateway 3545GZ Internet Card Replacement: passo 2, immagine 1 di 1
    • Carefully remove the flap over the internet card.
  3. Gateway 3545GZ Internet Card Replacement: passo 3, immagine 1 di 2 Gateway 3545GZ Internet Card Replacement: passo 3, immagine 2 di 2
    • Unhook the two cords attached to the internet card and remove the card.
    • Next, pull the two metal hooks holding the card in place away from each other.
    • The card should pop out and just take it out from the dock.
Conclusione
Baylee Harding
Membro da: 09/12/16
25 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 286
