Salta al contenuto principale
Gateway 3545GZ Hard Drive Replacement
Cosa ti serve
  1. Gateway 3545GZ Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip the laptop so that the bottom is facing you. You will find in the lower left-hand corner a hole with a small screw; unscrew this with a PH1 Phillips-head screwdriver (Has a plus shape).
    • Screw Length: 3mm
  2. Gateway 3545GZ Hard Drive Replacement: passo 2, immagine 1 di 1
    • Lift up the plastic plate from the outer edge.
  3. Gateway 3545GZ Hard Drive Replacement: passo 3, immagine 1 di 1
    • Finally, slide the hard drive out of its dock; then just lift the hard drive out of the pocket.
Conclusione
Bryan Rickle
Membro da: 09/12/16
1 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 291
