Salta al contenuto principale
Gateway 3545GZ Fan Replacement
Cosa ti serve
  1. Gateway 3545GZ Fan Replacement, Fan: passo 1, immagine 1 di 2 Gateway 3545GZ Fan Replacement, Fan: passo 1, immagine 2 di 2
    • Unscrew 14mm screws with Phillips screwdriver.
    • Unscrew 3mm screws with the same Phillips screwdriver.
    • Screws that are circled in red are 3mm; the screw circled in blue is 14mm
    • Remove the protective cover.
  2. Gateway 3545GZ Fan Replacement: passo 2, immagine 1 di 3 Gateway 3545GZ Fan Replacement: passo 2, immagine 2 di 3 Gateway 3545GZ Fan Replacement: passo 2, immagine 3 di 3
    • Unscrew the four screws holding it in place with the same PH1 Phillips-Head screwdriver. They are numbered on the fan, 1,2,3,4.
    • The four screws are 12mm long, they also have a spring surrounding them.
    • Then carefully pull the cord connecting the fan to the notebook.
    • Insert your replacement fan, plug in its cord, screw it into place, and reattach the protective cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 232
