Salta al contenuto principale
Gatekeeper Wheel Tread Replacement
  1. Gatekeeper Wheel Tread Replacement, Remove the Gatekeeper Wheel from the shopping cart.: passo 1, immagine 1 di 1
    • Using two 7/16th box wrenches, loosen and remove the nut, washer and bolt. Set aside to reuse.
  2. Gatekeeper Wheel Tread Replacement, Remove the damage/worn tread.: passo 2, immagine 1 di 1
    • Using a T-15 Torx bit, remove the five screws, then pry the old tread off the wheel.
  3. Gatekeeper Wheel Tread Replacement, Install new tread: passo 3, immagine 1 di 1
    • Line up the new tread on the wheel, then insert five new screws using a T-15 Torx bit
    • Replace the nut, washer and bolt that was removed in step 1
Conclusione
Documenti Allegati
LANE
Membro da: 12/06/21
599 Reputazione
2 Guide realizzate
The Home Depot Membro di The Home Depot
Community
22.491 Membri
62 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 371
