Introduzione
The seals of the inlet valve are under a lot of strain and need to be replaced from time to time. The replacement is easy. This will show you how to do this.
Cosa ti serve
Here you see the removed socket. Note the double O-rings.
Open the valve to do this, the slot at the upper end must be twisted a little, then the inside comes out. Check the spring, the valve stem and the two seals. When assembling, pay attention to the correct position of the valve stamp: it must point to the water inlet side, otherwise the valve will not open! (Third picture shows wrong direction)
Replace the seals on the nozzle and lightly grease them with food grade silicone grease.
Work through the steps in reverse order to re-assemble your device.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
