Salta al contenuto principale
Garmin nuviCam LMTHD Motherboard Replacement
Cosa ti serve
  1. Garmin nuviCam LMTHD Motherboard Replacement, Screen: passo 1, immagine 1 di 2 Garmin nuviCam LMTHD Motherboard Replacement, Screen: passo 1, immagine 2 di 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Motherboard Replacement: passo 2, immagine 1 di 2 Garmin nuviCam LMTHD Motherboard Replacement: passo 2, immagine 2 di 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Motherboard Replacement: passo 3, immagine 1 di 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Motherboard Replacement: passo 4, immagine 1 di 2 Garmin nuviCam LMTHD Motherboard Replacement: passo 4, immagine 2 di 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Disconnect battery wire from motherboard.
  6. Garmin nuviCam LMTHD Motherboard Replacement: passo 6, immagine 1 di 1
    • Disconnect yellow ribbon cable from motherboard.
  7. Garmin nuviCam LMTHD Motherboard Replacement: passo 7, immagine 1 di 1
    • Pull off black and red wire from screen.
  8. Garmin nuviCam LMTHD Motherboard Replacement: passo 8, immagine 1 di 1
    • Disconnect the orange cable strip connected to the screen using a plastic opening tool, lift white teeth up and slide strip out.
  9. Garmin nuviCam LMTHD Motherboard Replacement: passo 9, immagine 1 di 1
    • Remove silver plate from motherboard.
  10. Garmin nuviCam LMTHD Motherboard Replacement: passo 10, immagine 1 di 2 Garmin nuviCam LMTHD Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove all six 5.74mm screws from motherboard using the T4 screw bit.
  11. Garmin nuviCam LMTHD Motherboard Replacement: passo 11, immagine 1 di 2 Garmin nuviCam LMTHD Motherboard Replacement: passo 11, immagine 2 di 2
    • Lift motherboard out of device using plastic opening tools.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Where to buy the replacement mother board? I couldn't find one.
BTW: Nicely done guide.
pitt83 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 21
Tutti i Tempi: 616
