Salta al contenuto principale
Garmin nuviCam LMTHD Battery Replacement
Cosa ti serve
  1. Garmin nuviCam LMTHD Battery Replacement, Screen: passo 1, immagine 1 di 2 Garmin nuviCam LMTHD Battery Replacement, Screen: passo 1, immagine 2 di 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Battery Replacement: passo 2, immagine 1 di 2 Garmin nuviCam LMTHD Battery Replacement: passo 2, immagine 2 di 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Battery Replacement: passo 3, immagine 1 di 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Battery Replacement: passo 4, immagine 1 di 2 Garmin nuviCam LMTHD Battery Replacement: passo 4, immagine 2 di 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Battery Replacement, Battery: passo 5, immagine 1 di 1
    • Locate the white box in your device which is the battery.
  6. Garmin nuviCam LMTHD Battery Replacement: passo 6, immagine 1 di 1
    • Disconnect battery from device pulling the green, red, and black wires from motherboard.
  7. Garmin nuviCam LMTHD Battery Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect orange cable strip laying across battery by sliding it out of connector .
    • It may be at your benefit to use tweezers. It will be easier to reconnect the orange ribbon later with this tool.
  8. Garmin nuviCam LMTHD Battery Replacement: passo 8, immagine 1 di 1
    • Pry battery out of device.
    • Battery is glued into device, so it may be difficult to remove.
Conclusione
Altre 7 persone hanno completato questa guida.
4 Commenti
Where did you buy the battery? What is the voltage/current?
John Justin - Replica
It is nice to see how to remove the battery, but would like to have one handy before I start. Where can I buy one and what are the specifications?
Gary - Replica
I believe Garmin Part No. 361-00066-00 is correct (also used in the Nuvi 27xx series). It is available on AMazon and eBay.
guy.adamson - Replica
Anyone else having issues getting it to charge?
Just shows a red battery with a question mark.
Zach - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 4,969
