Salta al contenuto principale
Garmin nuvi 2460 LMT Speaker Replacement
Cosa ti serve
  1. Garmin nuvi 2460 LMT Speaker Replacement, Back Cover: passo 1, immagine 1 di 2 Garmin nuvi 2460 LMT Speaker Replacement, Back Cover: passo 1, immagine 2 di 2
    • Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
  2. Garmin nuvi 2460 LMT Speaker Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
  3. Garmin nuvi 2460 LMT Speaker Replacement: passo 3, immagine 1 di 1
    • Lift the beige clamp using a tweezer or your fingernail and remove the connector.
  4. Garmin nuvi 2460 LMT Speaker Replacement: passo 4, immagine 1 di 1
    • Lift the connector gently from the socket, making sure you pull in the right direction.
  5. Garmin nuvi 2460 LMT Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift and separate the speaker connector cable using a pair of tweezers.
  6. Garmin nuvi 2460 LMT Speaker Replacement: passo 6, immagine 1 di 1
    • Gently lift the speaker out of the back cover using a plastic opening tool.
    • Apply force as needed if there is glue holding the speaker in place.
Conclusione
USF Tampa, Team 6-4, Remmell Fall 2016 Membro di USF Tampa, Team 6-4, Remmell Fall 2016
USFT-REMMELL-F16S6G4
4 Membri
7 Guide realizzate
Un commento
Where do I get the parts for the garmin nuvi 2460? I can’t find anything online or ebay. I need a speaker and a microphone replacements!
Mark Peterson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 227
