Salta al contenuto principale
Garmin nuvi 2460 LMT Back Cover Replacement
Cosa ti serve
  1. Garmin nuvi 2460 LMT Back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 Garmin nuvi 2460 LMT Back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
  2. Garmin nuvi 2460 LMT Back Cover Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
  3. Garmin nuvi 2460 LMT Back Cover Replacement: passo 3, immagine 1 di 1
    • Lift the beige clamp using a tweezer or your fingernail and remove the connector.
  4. Garmin nuvi 2460 LMT Back Cover Replacement: passo 4, immagine 1 di 1
    • Lift the connector gently from the socket, making sure you pull in the right direction.
Conclusione
USF Tampa, Team 6-4, Remmell Fall 2016 Membro di USF Tampa, Team 6-4, Remmell Fall 2016
USFT-REMMELL-F16S6G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 567
