Salta al contenuto principale
Garmin fenix 6X Sapphire Display Replacement
Cosa ti serve
  1. Garmin fenix 6X Sapphire Display Replacement, Display: passo 1, immagine 1 di 1
    • Orient the watch so that the screen is face up.
    • Remove the five 6 mm black screws from the perimeter of the watch face using the T5 Torx screwdriver.
  2. Garmin fenix 6X Sapphire Display Replacement: passo 2, immagine 1 di 2 Garmin fenix 6X Sapphire Display Replacement: passo 2, immagine 2 di 2
    • Carefully lift up the watch face as it's attached to the motherboard by a ribbon connector.
    • Detach the black connector from the motherboard.
    • A spudger can be used if you have trouble prying the piece with your fingers.
    • Don't pull on the ribbon as it could tear.
    • When the ribbon is disconnected remove the watch face.
Conclusione
Altre 5 persone hanno completato questa guida.
matthew long
Membro da: 02/22/22
537 Reputazione
5 Guide realizzate
Clemson, Team 1-5, Hunter Spring 2022 Membro di Clemson, Team 1-5, Hunter Spring 2022
CLEM-HUNTER-S22S1G5
4 Membri
11 Guide realizzate
2 Commenti
hello matthew
where could you buy the display. i can't find any suppliers on the net
Mr. Wu - Replica
Hi! thank you for the tutorial! do you know if a non-sapphire crystal can be replaced with a sapphire one? I got the non-sapphire watch 2 years ago and I keep scratching it.
Dennis Savitskij - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 61
Ultimi 30 Giorni: 608
Tutti i Tempi: 8,006
