Salta al contenuto principale
Garmin fenix 6X Sapphire Back Cover Replacement
Cosa ti serve
  1. Garmin fenix 6X Sapphire Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the watch so the face is down.
    • Remove the five 6 mm T5 Torx screws on the back of the watch.
  2. Garmin fenix 6X Sapphire Back Cover Replacement: passo 2, immagine 1 di 3 Garmin fenix 6X Sapphire Back Cover Replacement: passo 2, immagine 2 di 3 Garmin fenix 6X Sapphire Back Cover Replacement: passo 2, immagine 3 di 3
    • Use a spudger to pry the back cover of the watch off by placing it under the seam of the back case.
    • The back cover is glued on and may be difficult to remove. It might help to heat the back cover before prying in order to soften the glue. If doing so, be careful to not burn yourself.
    • This step requires a good bit of force to pry or apply heat back cover off because the back cover is glued. Be careful not to the break cover from too much force.
Conclusione
matthew long
Membro da: 02/22/22
537 Reputazione
5 Guide realizzate
Clemson, Team 1-5, Hunter Spring 2022 Membro di Clemson, Team 1-5, Hunter Spring 2022
CLEM-HUNTER-S22S1G5
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 97
Tutti i Tempi: 2,299
