Salta al contenuto principale
Garmin Vivoactive HR Display Replacement
Cosa ti serve
  1. Garmin Vivoactive HR Display Replacement, Display: passo 1, immagine 1 di 1
    • Apply the Heated iOpener to the display for 30 seconds to soften the adhesive..
  2. Garmin Vivoactive HR Display Replacement: passo 2, immagine 1 di 1
    • Insert a spudger between the display and watch body.
    • Pry upwards and work the spudger around the perimeter of the display to free it from the body.
    • The display is still attached with ribbon cables so don't remove completely.
  3. Garmin Vivoactive HR Display Replacement: passo 3, immagine 1 di 1
    • Lift the touchscreen to expose ribbon cables that connect it to the main circuit board.
  4. Garmin Vivoactive HR Display Replacement: passo 4, immagine 1 di 2 Garmin Vivoactive HR Display Replacement: passo 4, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the display cable press connectors from the motherboard.
Conclusione
Altre 16 persone hanno completato questa guida.
Chris Corry
Membro da: 07/05/18
256 Reputazione
1 Guida realizzata
IUPUI, Team S2-G5, Harley Summer 2018 Membro di IUPUI, Team S2-G5, Harley Summer 2018
IUPUI-HARLEY-SU18S2G5
3 Membri
3 Guide realizzate
19 Commenti
Hello,
thanks for this. Where can i buy the new screen?
Bowland Olan - Replica
Nice guide! Thanks. But I can’t find any parts to repair my watch
Christoph Freydank - Replica
Yeah, where can we get the parts from? Also how hard is it to change the battery? Thanks for your help :)
Rick - Replica
What type of glue i use to connect the display an the body?
culibrkboj - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 82
Tutti i Tempi: 25,953
