Salta al contenuto principale
Garmin StreetPilot c320 Rear Case Assembly Replacement
Cosa ti serve
  1. Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: passo 1, immagine 1 di 2 Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: passo 1, immagine 2 di 2
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Garmin StreetPilot c320 Rear Case Assembly Replacement: passo 2, immagine 1 di 2 Garmin StreetPilot c320 Rear Case Assembly Replacement: passo 2, immagine 2 di 2
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Garmin StreetPilot c320 Rear Case Assembly Replacement: passo 3, immagine 1 di 1
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
Conclusione
Andrew Burman
Membro da: 01/18/12
1 Reputazione
1 Guida realizzata
Cal Poly, Team 11-19, Maness Winter 2012 Membro di Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,403
