Salta al contenuto principale
Garmin StreetPilot c320 LCD Screen Replacement
Arturo Barajas
Arturo Barajas e 7 altri collaboratori
Ultimo aggiornamento il July 8, 2020
15 minuti
Moderato
Foto Azione
Introduzione
Vai al passo 1
For this guide you will be opening the device, but it is fairly simple. Before you begin disassembling the device, be sure the power is off.
Cosa ti serve
Strumenti
Mostra di più…
  1. Garmin StreetPilot c320 LCD Screen Replacement, Rear Case Assembly: passo 1, immagine 1 di 2 Garmin StreetPilot c320 LCD Screen Replacement, Rear Case Assembly: passo 1, immagine 2 di 2
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Garmin StreetPilot c320 LCD Screen Replacement: passo 2, immagine 1 di 2 Garmin StreetPilot c320 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Garmin StreetPilot c320 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
  4. Garmin StreetPilot c320 LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 1
    • Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
  5. Garmin StreetPilot c320 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Slightly lift the motherboard upwards to reveal the LCD assembly.
    • Do not remove the motherboard yet, as it is stil attached to the LCD.
  6. Garmin StreetPilot c320 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Use the edge of a plastic opening tool to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the plastic opening tool to pull the LCD ribbon cable out of its socket.
    • Disconnect the right connector using the edge of a plastic opening tool.
Conclusione
Cal Poly, Team 11-19, Maness Winter 2012 Membro di Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,556
