Salta al contenuto principale
Garmin Nuvi 65LM Car Charger Fuse Replacement
Cosa ti serve
  1. Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: passo 1, immagine 1 di 3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: passo 1, immagine 2 di 3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: passo 1, immagine 3 di 3
    • Hold the car charger with your hands so the metal tip is facing towards you.
    • Insert the flat end of the spudger into the slotted grove of the black plastic surrounding the metal tip by pressing down on the tip.
    • Simultaneously press down and turn the spudger counter-clockwise 90 degrees to unlock the black plastic cap.
  2. Garmin Nuvi 65LM Car Charger Fuse Replacement: passo 2, immagine 1 di 3 Garmin Nuvi 65LM Car Charger Fuse Replacement: passo 2, immagine 2 di 3 Garmin Nuvi 65LM Car Charger Fuse Replacement: passo 2, immagine 3 di 3
    • Carefully take off the black plastic cap surrounding the charging tip with your hands.
    • Use your hands to pull off the silver metal tip away from the charger.
  3. Garmin Nuvi 65LM Car Charger Fuse Replacement: passo 3, immagine 1 di 1
    • Turn the charger compartment over and carefully dump the fuse into your hand.
Conclusione
Cal Poly, Team 15-3, Amido Spring 2015 Membro di Cal Poly, Team 15-3, Amido Spring 2015
CPSU-AMIDO-S15S15G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,083
