Salta al contenuto principale
Garmin Nuvi 56LMT Battery Replacement
Cosa ti serve
  1. Garmin Nuvi 56LMT Battery Replacement, Battery: passo 1, immagine 1 di 2 Garmin Nuvi 56LMT Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Before disassembling, power off the device.
    • There are four 11.0 mm screws located at each corner on the back of the device.
    • With the T5 torx screwdriver, remove these screws and set aside in a safe place.
  2. Garmin Nuvi 56LMT Battery Replacement: passo 2, immagine 1 di 3 Garmin Nuvi 56LMT Battery Replacement: passo 2, immagine 2 di 3 Garmin Nuvi 56LMT Battery Replacement: passo 2, immagine 3 di 3
    • Using the plastic opening tool, pry apart the device around the seam.
  3. Garmin Nuvi 56LMT Battery Replacement: passo 3, immagine 1 di 3 Garmin Nuvi 56LMT Battery Replacement: passo 3, immagine 2 di 3 Garmin Nuvi 56LMT Battery Replacement: passo 3, immagine 3 di 3
    • Observe the ribbon connecting the screen to the circuit board.
    • Detach the clip using the plastic opening tool and set aside the screen.
  4. Garmin Nuvi 56LMT Battery Replacement: passo 4, immagine 1 di 3 Garmin Nuvi 56LMT Battery Replacement: passo 4, immagine 2 di 3 Garmin Nuvi 56LMT Battery Replacement: passo 4, immagine 3 di 3
    • Using the T5 Torx screwdriver, remove the two remaining 5.0 mm screws.
    • Lift the board from its housing and then detach the plug coming from the battery.
  5. Garmin Nuvi 56LMT Battery Replacement: passo 5, immagine 1 di 1
    • If the battery is glued in place use the plastic opening tool to remove it.
    • Finally, exchange the old battery with the replacement.
Conclusione
USF Tampa, Team S3-G5, Nance Fall 2017 Membro di USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 422
