Salta al contenuto principale
Garmin Nuvi 50LM Power Button Replacement
Cosa ti serve
  1. Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: passo 1, immagine 1 di 2 Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: passo 1, immagine 2 di 2
    • Use the T-4 screwdriver to unscrew the 9 mm screws on the back of the device.
  2. Garmin Nuvi 50LM Power Button Replacement: passo 2, immagine 1 di 2 Garmin Nuvi 50LM Power Button Replacement: passo 2, immagine 2 di 2
    • Pry open the device from all four sides using the iFixit Plastic Opening Tool until you see the inside of the system.
  3. Garmin Nuvi 50LM Power Button Replacement: passo 3, immagine 1 di 2 Garmin Nuvi 50LM Power Button Replacement: passo 3, immagine 2 di 2
    • Look for a small button on the motherboard at the top of the device, and insert replacement power button on top of the small button on the motherboard until you hear a click.
Conclusione
Altre 2 persone hanno completato questa guida.
3 Commenti
Does not help me a bit. My button fell off and I did not see it come off, so it is lost. Cannot fix it without info of where to get a replacement!
Denny Manning - Replica
The power button on my Garmin 50 LM fell off the other day. I can’t find anywhere where I can buy a new replacement. Any suggestions would be much appreciated. Thank you!
Mary - Replica
I’m looking for same switch part for nuvi 40lm. Unless we purchase a whole
Unit from EBay that doesn’t work just for the switch. Good luck if you find one.
Erik Pistek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 24
Tutti i Tempi: 6,843
