Salta al contenuto principale
Garmin Nuvi 2797LMT LCD Screen Replacement
Cosa ti serve
  1. Garmin Nuvi 2797LMT LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Before you begin make sure your device is turned off.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT LCD Screen Replacement: passo 2, immagine 1 di 3 Garmin Nuvi 2797LMT LCD Screen Replacement: passo 2, immagine 2 di 3 Garmin Nuvi 2797LMT LCD Screen Replacement: passo 2, immagine 3 di 3
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT LCD Screen Replacement: passo 3, immagine 1 di 1
    • Locate the ribbon attached to the motherboard. Carefully detach the ribbon.
  4. Garmin Nuvi 2797LMT LCD Screen Replacement: passo 4, immagine 1 di 1
    • Using your T-4 Torx Screwdriver, unscrew the four 2.38 mm Torx T-4 screws from the back of your screen.
  5. Garmin Nuvi 2797LMT LCD Screen Replacement: passo 5, immagine 1 di 2 Garmin Nuvi 2797LMT LCD Screen Replacement: passo 5, immagine 2 di 2
    • Now pulling up on one of the corners, bring the top half of the casing out of the bottom half.
  6. Garmin Nuvi 2797LMT LCD Screen Replacement: passo 6, immagine 1 di 2 Garmin Nuvi 2797LMT LCD Screen Replacement: passo 6, immagine 2 di 2
    • Now remove the front casing and back casing away from the screen. You will end up with three separate pieces.
Conclusione
Altre 4 persone hanno completato questa guida.
2 Commenti
Instructions lacking. Go here, https://www.youtube.com/watch?v=iMotyMvC... . Not the exact same Garmin, but virtually the same and worked much better than the instructions here!!
allen1 - Replica
Still can't get my older Garmin back in working order.
where can i take it for someone else to re-cycle it as I have a brand new one .
Thomas L Camp - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,319
