Salta al contenuto principale
Garmin Nuvi 2597LMT Battery Replacement
Cosa ti serve
  1. Garmin Nuvi 2597LMT Battery Replacement, Battery: passo 1, immagine 1 di 2 Garmin Nuvi 2597LMT Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn your device over so the back is revealed and you can see the screws in the four corners.
    • Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
  2. Garmin Nuvi 2597LMT Battery Replacement: passo 2, immagine 1 di 3 Garmin Nuvi 2597LMT Battery Replacement: passo 2, immagine 2 di 3 Garmin Nuvi 2597LMT Battery Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to pry open the device at the seam where the two halves meet, prying all along the sides and the top seams if need be.
    • Do it slowly so you don't accidently rip the ribbon cable that connects the digitizer to the motherboard, as well as don't completely separate the halves as this can tear the ribbon cable.
  3. Garmin Nuvi 2597LMT Battery Replacement: passo 3, immagine 1 di 2 Garmin Nuvi 2597LMT Battery Replacement: passo 3, immagine 2 di 2
    • Locate the battery and then use your spudger to gently lift the battery, which is held to the case using a sticky pad, and free it from its position.
    • When you remove the battery, do so slowly so that the wires connecting it to the motherboard aren't torn. The wires will be disconnected in the next step.
  4. Garmin Nuvi 2597LMT Battery Replacement: passo 4, immagine 1 di 2 Garmin Nuvi 2597LMT Battery Replacement: passo 4, immagine 2 di 2
    • Use your hands or a spudger to gently lift the wires from underneath to disconnect the connector from the motherboard.
    • Once you have disconnected the battery from the motherboard, you can safely set it aside.
Conclusione
Altre 7 persone hanno completato questa guida.
USF Tampa, Team 1-4, Sullivan Fall 2016 Membro di USF Tampa, Team 1-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G4
4 Membri
5 Guide realizzate
2 Commenti
Great guide. The only thing I might add is you may need magnifiers to see which side of the connector goes down as you reverse step 4. I bought a set of Husky star drivers on Amazon. The bits store in the handle so easy to keep. Start to finish on this job with this guide was maybe 15 minutes. Thanks.
myfblogin - Replica
Great guide, just a little tip. BEFORE dismantling old battery connector from the motherboard, put a dab of Tippex on it so you can match the 'upside' to the new battery connector. Just makes re-attaching that bit easier...
Stephen M - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 40
Tutti i Tempi: 3,595
