Salta al contenuto principale
Garmin Nuvi 2595LMT LCD Screen Replacement
Cosa ti serve
  1. Garmin Nuvi 2595LMT LCD Screen Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: passo 1, immagine 1 di 1
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT LCD Screen Replacement: passo 2, immagine 1 di 2 Garmin Nuvi 2595LMT LCD Screen Replacement: passo 2, immagine 2 di 2
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT LCD Screen Replacement: passo 3, immagine 1 di 3 Garmin Nuvi 2595LMT LCD Screen Replacement: passo 3, immagine 2 di 3 Garmin Nuvi 2595LMT LCD Screen Replacement: passo 3, immagine 3 di 3
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
  4. Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 2 Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: passo 4, immagine 2 di 2
    • Grabbing the top half of the Nuvi, remove the screen from the tabs holding it in place using thumbs.
    • Place screen on table.
  5. Garmin Nuvi 2595LMT LCD Screen Replacement: passo 5, immagine 1 di 2 Garmin Nuvi 2595LMT LCD Screen Replacement: passo 5, immagine 2 di 2
    • Place new screen in proper position, with the ribbon facing downward.
Conclusione
Altre 2 persone hanno completato questa guida.
3 Commenti
cannot prise open the connector to replace ribbon
norman bayne - Replica
My screen is cracked. The screen opens, but I can't use the key board.
Thank You For any Help You Can Give Me,
Cookie
cookiecaafato1@yahoo.com nuvi 2595 LMT
cookiecalafato1 - Replica
Re-seating the ribbon is simply impossible.
daBee - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 4,578
