Introduzione
If your speaker is defective, obtain a new speaker and replace the old one with the new working speaker.
  1. Remove the barcode sticker at the bottom of the device.
    • Remove the barcode sticker at the bottom of the device.
  2. Remove two 8.4 mm T5 screws from the bottom of the device.
    • Remove two 8.4 mm T5 screws from the bottom of the device.
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
    • Remove the power button.
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
    • Carefully disconnect the speaker from the motherboard. Slowly wiggling the connection makes it easier to disconnect.
    • Using a plastic opening tool, wedge the speaker away from the device. The speaker is glued to the case so use force and leverage.
Conclusione
Timothy
Membro da: 26/01/2012
41 Reputazione
3 Guide realizzate
Cal Poly, Team 9-3, Regan Winter 2012 Membro di Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Membri
4 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,709
