Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
If your power button is defective, replace the old one with the new power button.
  1. Remove the barcode sticker at the bottom of the device.
    • Remove the barcode sticker at the bottom of the device.
  2. Remove two 8.4 mm T5 screws from the bottom of the device.
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Using a plastic opening tool, carefully pry open the device. Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  5. Remove the power button. Remove the power button.
    • Remove the power button.
Conclusione
Timothy
Membro da: 26/01/2012
56 Reputazione
3 Guide realizzate
Cal Poly, Team 9-3, Regan Winter 2012 Membro di Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 17
Tutti i Tempi: 9,347
