Salta al contenuto principale
Introduzione
Removing the logic board from the Garmin Nuvi 200
  1. Peel off the sticker from the bottom of the device to reveal two screws. Peel off the sticker from the bottom of the device to reveal two screws.
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Remove two T5 Torx screws.
    • Remove two T5 Torx screws.
  3. Insert a plastic opening tool in the gap between the front and rear casing. Carefully work the tool around the gap, separating the two halves of the case.
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  5. Peel away the tape holding the ribbon cable in place.
    • Peel away the tape holding the ribbon cable in place.
    • Disconnect the ribbon cable by using a spudger to flip up the retaining flap on its ZIF-style connector. Then gently remove the cable.
  6. Pull out the cable between the logic board and the speaker to disconnect them.
    • Pull out the cable between the logic board and the speaker to disconnect them.
  7. Remove the three screws from the logic board using the #00 Phillips screwdriver. Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
    • Remove the three screws from the logic board using the #00 Phillips screwdriver.
    • Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
  8. Detach the logic board form the battery by pulling out the cable. Detach the logic board form the battery by pulling out the cable.
    • Detach the logic board form the battery by pulling out the cable.
Conclusione
Anjelica
Membro da: 11/04/2010
504 Reputazione
3 Guide realizzate
Cal Poly, Team 25-90, Amido Spring 2010 Membro di Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 9,731
