Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Use this guide to replace the battery in the Garmin Nuvi 255W.
  1. Remove the barcode sticker at the bottom of the device.
    • Remove the barcode sticker at the bottom of the device.
  2. Remove two 8.4 mm T5 screws from the bottom of the device.
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Using a plastic opening tool, carefully pry open the device. Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
    turn the unit around
    Andrew Hayden - Replica
    Since there is no replacement speaker whats the point of this process?
    greg - Replica
    Very detailed set of instructions! Does anyone known the thread size of the screws in step 2? 8.4 mm T5 screws: is the length of the screw (8.4 mm) ,and the head specification (T5- size of screw driver). I need the actual thread specification. I lost one of the screws and the other one 's head is stripped. I need to replace both screws.
    Harold Schultz - Replica
  4. Kit cacciaviti Manta
    112 punte per ogni riparazione.
    Upgrade Your Toolbox
  5. Remove the power button. Remove the power button.
    • Remove the power button.
    Where can I buy the button
    milosvalek - Replica
  6. Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  7. Lift up the motherboard. Carefully disconnect the battery and motherboard.  Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  8. Using the plastic opening tool as a wedge, pry the battery from the case.  This can be fairly tough as the battery is glued to the case.  Don't be afraid to use force and some good leverage. Using the plastic opening tool as a wedge, pry the battery from the case.  This can be fairly tough as the battery is glued to the case.  Don't be afraid to use force and some good leverage.
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
    ottima guida ho perso ar
    Francesco Renon - Replica
Conclusione
Altre 11 persone hanno completato questa guida.
Timothy
Membro da: 26/01/2012
56 Reputazione
3 Guide realizzate
Cal Poly, Team 9-3, Regan Winter 2012 Membro di Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Membri
4 Guide realizzate
Thanks for this very nicely illustrated guide.
RBStorms - Replica
Thanks for the guide. Used it to open up a Nuvi 265 because the battery had been left to discharge below the protection circuit's limit. Connected the battery leads (Green = ground, Red = voltage, Black = temperature) to a 5v USB charger for ~20 seconds to revive the protection circuit, and the unit is now charging again. If you're going to do this, know the risks. Thermal runaways in lithium batteries can be extremely volatile.
rbol - Replica
Used these instructions to replace battery in my 5-year old Garmin nuvi 205W (which has the same access and internal geometry).
JRedmond - Replica
Thanks, great demonstration.
peter2x4 - Replica
This is great! I have run into a big problem, though. One of the screws is "unthreaded." The head has become smooth, and I can't unscrew it to get the cover off. Is there any way to get it off???
nancyw - Replica
There are screw bits made specially to extract stripped screws, but if the screw isn't too far below the surface it's going through, the cheap way is to file or grind a slot into the head so you can extract it with a jeweller's flathead.
rbol -
Kein Problem, keine 10 Minuten gebraucht, um im nüvi 255W den Akku zu wechseln!
w.gerrit - Replica
Thanks, esp for an amatuer born before Torx and Phillips and old enough to have learnt not to throw things away.
Maxwell Jordan
Maxwell Jordan - Replica
Thank you for the guide as it is very helpful! Here's the replacement battery needed for the Garmin Nuvi 255W. It's brand new, it comes with all the necessary installation tools and it has a 1 year warranty! Garmin Nuvi 255W Replacement Battery
Mike - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 63
Tutti i Tempi: 23,956
