Salta al contenuto principale
Garmin Nuvi 2557LMT Screen Replacement
Cosa ti serve
  1. Garmin Nuvi 2557LMT Screen Replacement, Garmin Nuvi 2557LMT Disassembly: passo 1, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Screen Replacement: passo 2, immagine 1 di 1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Screen Replacement: passo 3, immagine 1 di 1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Screen Replacement: passo 4, immagine 1 di 2 Garmin Nuvi 2557LMT Screen Replacement: passo 4, immagine 2 di 2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Screen Replacement, Screen: passo 5, immagine 1 di 1
    • With the screen facing down, firmly grip the sides of the screen frame and pop the screen out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 460
