Salta al contenuto principale
Garmin Nuvi 2557LMT Motherboard Replacement
Cosa ti serve
  1. Garmin Nuvi 2557LMT Motherboard Replacement, Garmin Nuvi 2557LMT Disassembly: passo 1, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Motherboard Replacement: passo 2, immagine 1 di 1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Motherboard Replacement: passo 3, immagine 1 di 1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Motherboard Replacement: passo 4, immagine 1 di 2 Garmin Nuvi 2557LMT Motherboard Replacement: passo 4, immagine 2 di 2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Motherboard Replacement, Battery: passo 5, immagine 1 di 1
    • Using a plastic opening tool pry the battery away from the device.
    • The battery might be glued, so it might require a little bit of force to get it out.
  6. Garmin Nuvi 2557LMT Motherboard Replacement: passo 6, immagine 1 di 1
    • Pull the battery-motherboard connector away from the motherboard.
  7. Garmin Nuvi 2557LMT Motherboard Replacement, Speaker: passo 7, immagine 1 di 1
    • Using a plastic opening tool, wedge the speaker from the device.
    • Don't pull it out of the device too far. It is still connected to the motherboard wire.
  8. Garmin Nuvi 2557LMT Motherboard Replacement: passo 8, immagine 1 di 1
    • Using a soldering iron, desolder the wire connection between the speaker and the device.
  9. Garmin Nuvi 2557LMT Motherboard Replacement, Motherboard: passo 9, immagine 1 di 1
    • Using a T5 Torx Screwdriver, remove the 5mm screws in the four corners of the motherboard.
  10. Garmin Nuvi 2557LMT Motherboard Replacement: passo 10, immagine 1 di 1
    • Using a plastic opening tool, pry the motherboard away from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 447
